21 years ago
Ethernet won't work
Hi people
I'm using a SMC9113 chip for my ethernet.
My problem is that it seems it won't work properly. It looks like the init of the chip is OK but take a look below to see the error msg.
Linux version 2.6.11-uc0 (mse@ECT-MSE) (gcc version 3.4.1 (Altera Nios II 5.0 b7
3))# 49 Fri Jul 29 08:58:56 WEDT 2005
uClinux/Nios II
Altera Nios II support (C) 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 003F0000
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6348k/8192k RAM, 0k/0k ROM (1433k kernel code, 293k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x804028e0 (irq = 0) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
 Now entering smc_init()
Lets do some smc_probing 4 counter=0
smc_probe: 100000 Khz Nios
BB_MODI activated 4
BB_MODI bank 3303; ioaddr(410300) + BANK_SELECT = 41030e
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
 IRQ 4
eth0: SMC91C11xFD(rev:1) at 0x410300 IRQ:4 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed
:00:00:00
Yeehaa we grabbed the IRQ successfully
Something caused us to break - smc_probe returned 0 but has IRQ: 4 on address: 4
10300
Now returning dev from sub-function .....this ought to be the end of it!
BB_MODI activated 4
Oh bugger ....something is wrong IRQ=0
smc91111.c goto out (1)
cfi_probe.c:: cfi_probe_init
microtronix.c::init_microtronix_map start
MSE __ioremap
chipreg.c::do_map_probe for: cfi_probe
chipreg.c::get_mtd_chip_driver
cfi_probe.c:: base=0;
cfi.h::cfi_build_cmd chip_mode 1; chips_per_word 1
cfi_probe.c:: qry_present base=0; osf=1
CFI_PROBE.c MSE qry failed!
cfi_probe.c:: !qry_present
cfi_probe.c:: qry_present base=0; osf=2
cfi_probe.c:: qry_present base=0; osf=4
do_map_probe:: return NULL(2)
chipreg.c::do_map_probe for: jedec_probe
microtronix.c::init_microtronix_map device NOT added
3))# 46 Mon Jul 25 15:27:47 WEDT 2005
uClinux/Nios II
Built 1 zonelists
Memory available: 7040k/8192k RAM, 0k/0k ROM (842k kernel code, 210k data)
Linux NoNET1.0 for Linux 2.6
MSE microtronix.c 1 BUSWIDTH 1;WINDOW_ADDR 0;WINDOW_SIZE 400000
MSE __ioremap
MSE microtronix.c 2
cfi_probe.c:: cfi_probe_chip
cfi_probe.c:: cfi_chip_setup
Microtronix map: Found 1 x16 devices at 0x0 in 8-bit bank
 Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
MSE microtronix.c 3
Using Microtronix development partition definition
Creating 2 MTD partitions on "Microtronix map":
0x00200000-0x00300000 : "romfs"
0x00000000-0x00200000 : "loader/kernel"
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 52k freed (0x10f0000 - 0x10fc000)
#  ls
ls
bin        dev        etc        home       mnt        proc       ramfs.img
sbin       sys        tmp        usr        var        #  cd sbin
cd sbin#  ls
ls#  cd ..
cd ..#  ifconfig
ifconfig
No usable address families found.
socket: Function not implemented#  ifconfig eth0 10.0.0.199 netmask 255.255.0.0 broadcast 10.0.0.255
Anyone know what the problem could be???
Michael E
