19 years agoethernet support
Hi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif i use the Nios2 dev Board (2c35). and try uclinux . I followed the instructions from this site http://nioswik...
19 years agoIt is in kernel config,
cd ~/uClinux-dist make menuconfig Kernel/Library/Defaults Selection ---> (linux-2.6.x) Kernel Version (None) Libc Version [ ] Default all settings (lose changes) [*] Customize Kernel Settings [ ] Customize Vendor/User Settings [ ] Update Default Vendor Settings Then <exit> <exit> <yes> . It will enter kernel config, Then in the kernel config menu, you can find the "Networking" in the top level.
