22 years agoEthernet not work when nios board updated to Nios2
I have bought a nios board from Altera with cyclone 1c20. The board works fine under nios1. But when i update the board from nios1 to nios 2 using factory_recovery file, the ethernet doesn't work...
22 years agoI think this is a bug that we fixed i then next release (coming to your home soon... can't say when). We found that this was usually so,lved by using a hub, which it soulds like you are using.
We also found that if you run the windows updates and get the critical updates all installed it works also. What OS are you on? Email me off line if updating windows doesn't help. I can try to get you a new file. [email protected]
