22 years agoEthernet not work when nios board updated to Nios2
I have bought a nios board from Altera with cyclone 1c20. The board works fine under nios1. But when i update the board from nios1 to nios 2 using factory_recovery file, the ethernet doesn't work...
22 years agoHi,niosIIuser
The Ethernet cable and the hub are OK. Because when I program the flash memory of the board with NIOS1 default file, the ethernet works fine using the same ethernet cable and hub. Regards. writer
