22 years agoEthernet not work when nios board updated to Nios2
I have bought a nios board from Altera with cyclone 1c20. The board works fine under nios1. But when i update the board from nios1 to nios 2 using factory_recovery file, the ethernet doesn't work...
22 years agoDear Kerri,
My board serial no is ASJ030401865, I update it using following steps: 1. Apply power to NIOS board, using JTAG to config 1c20 with restore_cyclone_1c20.sof 2. Open a Nios II SDK Shell, and change directory to the factory_recovery 3. Run the flash-restoration script: ./restore_my_flash 4. Following the script¡¯s instruction, 5. After program the flash memory, using JTAG to reprogram EPM7128AE with config_controller.pof 6. Repower NIOS board, And the first line of LCD shows NIOS II , the second line roll a message of http server . Connect one end of the RJ45 cable to the RJ1 , Connect the other end to hub, both LED in RJ1 are off. ( When in NIOS I , link LED is on, and the other LED is blinking). Best Regards. writer
