20 years agoEthernet Device Driver
I am working with a nios development board with a stratixII_2s60. I am trying to write my own ethernet device driver for an Ethernet MAC called "rtmac" that was build at my institute. Following the advise in the nios II software developer's handbook I startet out with the device driver for the lan91c111 called "altera_avalon_lan91c111" and changed it according to my needs. When altera_avalon_rtmac.h is compiled I get the error: error: `name' undeclared here (not in a function)[/cygdrive/z/Altera_examples/vhdl/niosII_stratixII_2s60_ES/testsys/rtmac/UCOSII/inc/altera_avalon_rtmac.h] web_server_6 line 102 12. Does anyone have an idea why this error occurs? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif I would be very happy for any answer! Here is my code for the altera_avalon_rtmac.h: -----------------------------------------------------------------------------------------------# ifndef __ALTERA_AVALON_RTMAC_H__ # define __ALTERA_AVALON_RTMAC_H__ # ifdef LWIP# include <stdlib.h># include <stdio.h># include "alt_types.h"# include "system.h"# include "lwip/netif.h"# include "arch/sys_arch.h"# include "alt_lwip_dev.h"# include "sys/alt_warning.h" # ifdef __cplusplus extern "C" {# endif /* __cplusplus */ err_t alt_avalon_rtmac_init(struct netif *netif); void alt_avalon_rtmac_rx(); typedef struct { alt_lwip_dev_list lwip_dev_list; int base_addr; int irq; // a DATA_BUS_WIDTH is not listed in system.h for the rtmac_0 // int bus_width; sys_sem_t semaphore; alt_u8 tx_packet_no; /* Number of packet allocated for Tx */ }alt_avalon_rtmac_if; # define ALTERA_AVALON_RTMAC_INSTANCE(name, dev) \ alt_avalon_rtmac_if dev = { { ALT_LLIST_ENTRY, { 0, name##_NAME, alt_avalon_rtmac_init, alt_avalon_rtmac_rx, }, }, name##_BASE, // a Register_offset is not listed in system.h for the rtmac_0 // name##_BASE + name##_RTMAC_REGISTERS_OFFSET, name##_IRQ, // a DATA_BUS_WIDTH is not listed in system.h for the rtmac_0 // name##_RTMAC_DATA_BUS_WIDTH, 0, 0 }; # define ALTERA_AVALON_RTMAC_INIT(name, dev) if (name##_IRQ == ALT_IRQ_NOT_CONNECTED) { ALT_LINK_ERROR ("Error: Interrupt not connected for "# dev ". " "The ALTERA Avalon rtmac driver requires that an " "interrupt is connected. Please select an IRQ for " "this device in SOPC builder."); } // a DATA_BUS_WIDTH is not listed in system.h for the rtmac_0 // else if (name##_RTMAC_DATA_BUS_WIDTH != 32) // { // ALT_LINK_ERROR ("Error: Invalid configuration for "# dev ". " // "The ALTERA Avalon rtmac driver currently only " // "supports the configuration of MAC/PHY on the " // "development board. Please select this option " // "in SOPC builder."); // } else { alt_lwip_dev_reg(dev); } # ifdef __cplusplus }# endif /* __cplusplus */ # else# warning excluding drivers for the rtmac as you do not have the LWIP software component selected# define ALTERA_AVALON_RTMAC_INSTANCE(name, dev) extern int alt_no_storage# define ALTERA_AVALON_RTMAC_INIT(name, dev) while(0) # endif /* LWIP */ # endif /* __ALTERA_AVALON_RTMAC_H__ */1 Reply
I finally found my mistake: Something was wrong with the comments I insterted within the# define areas. When I deleted them. There were no errors anymore. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
