21 years agoEthernet connection doesn't work properly(LWIP)
Hi all, I have problems with Ethernet connection with Altera Cyclone Dev Kit powered by Nios2. I have tested the Ethernet connection via hub with standalone LWIP and factory settings(www-server...
21 years agoThanks for your reply tns1!
Yes, in both situations there is a static IP setup. When the development board is connected straight to PC a crossover cable was used else another cable was used. Now I have noticed that if the ethernet cable is connected after the board has booted itself, the connection is working properly in hub-situation. -CoolMan http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
