20 years agoEthernet Communication with Stratix II EP2S30
I have to realise an interface between a camera and a computer for image processing, and the data need to be transmitted via an ALTERA Stratix II EP2S30 card. I made all the researches I could to find an answer to my question, without a real result. How can I reach a 68Mbs transmission rate with my SMSC LAN91C111 chip ? (I didn't find a free IP which could do this !!!). If someone have any experience about Ethernet communication between an Altera card and a computer, please feel free to tell me ! Thanks you for your attention, Regards, Lord Redbeard.2 Replies
--- Quote Start --- originally posted by lord_redbeard@Mar 13 2006, 09:24 AM hello,i have to realise an interface between a camera and a computer for image processing, and the data need to be transmitted via an altera stratix ii ep2s30 card.
i made all the researches i could to find an answer to my question, without a real result.
how can i reach a 68mbs transmission rate with my smsc lan91c111 chip ? (i didn't find a free ip which could do this !!!).
if someone have any experience about ethernet communication between an altera card and a computer, please feel free to tell me !
thanks you for your attention,
regards,
lord redbeard.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13381)
--- quote end ---
--- Quote End --- Do a search for LAN91C111, there's several threads about how to increase transmission speeds. I think a user named revolt had the best results. I haven't done the work myself because transmission speed isn't an issue but I remember seeing a lot of discussion about it. The biggest speedup would likely be using DMA with the onboard chip. The default (meaning, how the included driver does it) method of sending a packet to the chip is a loop that sends it 32 bits at a time. Very CPU intensive.
Yep thanks.
I have done some search for my TCP interface and then reduced my needed output data rate to 9 Mbits/s for TCP. It is said that i must use DMA to stronlgy improve my data rate (and HW checksum too); data rate is basically evaluated to 450 kbits/s in TCP Tx by Altera without optimisations. To be continued...
