13 years agoEthernet autonegotiation
I am just wondering what kind of procedures are running during the link establishment in 100Base-T ethernet in case auto negotiation is disabled (i.e. forced mode) at both ends of the ethernet con...
13 years agoThe actual PMD spec for 100Base-TX is covered by the FDDI TP-PMD standard, it's not in 802.3. It's a 3 level analog signal, nothing you can interface an FPGA directly to without some external components. If you're attaching to a PHY, all you need is an MII, and you can obtain link status (etc) from the PHY's MDIO interface.
