20 years agoEthernet autodetect IRQ failure
Hi, all. I'm using Nios II on the Altera Stratix 1s10 eval board; I'm using std_1s10.ptf, and standard.sof. I successfully followed the instructions in http://forum.niosforum.co...
20 years ago --- Quote Start --- originally posted by therrien@May 15 2006, 10:04 AM thanks, hippo.
i tried the full-featured cpu (including "make clean" in linux-2.6.x), but it doesn't boot. it gets as far as this:
uncompressing linux... ok, booting the kernel.
linux version 2.6.11-uc0 (digaetas@server) (gcc version 3.4.6)# 14 sun may 14 22
:59:02 edt 2006
uclinux/nios ii
altera nios ii support (c) 2004 microtronix datacom ltd.
built 1 zonelists
kernel command line:
pid hash table entries: 128 (order: 7, 2048 bytes)
and that's it...oh well, perhaps i should restart the compile from scratch and try again.
btw...where did you look in the ptf file to find the irq number? there are many fields in that file which could represent irq number; i'm not familiar with the file format.
thanks,
-- therrien
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15367)</div> --- Quote End --- The execption vector (irq service) must be in sdram.
