20 years agoEthernet autodetect IRQ failure
Hi, all. I'm using Nios II on the Altera Stratix 1s10 eval board; I'm using std_1s10.ptf, and standard.sof. I successfully followed the instructions in http://forum.niosforum.co...
20 years agoI didn't look into to drivers code.
But I take a look at the irq number for lan91c111, it is "0" (zero) for standard ptf. It is not good for uClinux, irq 0 used to be auto-detect, and that is not supported. You will have to change the irq number in sopc builder. Then regenerate hardware, and kerenl from hwselect. Or you can use full_featured.
