16 years agoethernet auto-negotiation blocked?
Hi, I'm building a data acquisition and transfer system using Ethernet. The data source is continuous and has a throughput of 160 Mbps. Since the onboard Ethernet only supports 10/100 Base-T, I'm con...
16 years agoThank you very much, slacker. I fixed the problem according to your suggestion. Now my system can work well. Thank you again!
best, Eunice
