16 years agoethernet auto-negotiation blocked?
Hi, I'm building a data acquisition and transfer system using Ethernet. The data source is continuous and has a throughput of 160 Mbps. Since the onboard Ethernet only supports 10/100 Base-T, I'm con...
16 years agoNope. Like with other systems, malloc() allocates space on (from) the heap.
Otherwise, you'd have to set aside portions of your SDRAM using custom linker script techniques. Cheers, - slacker
