16 years agoethernet auto-negotiation blocked?
Hi, I'm building a data acquisition and transfer system using Ethernet. The data source is continuous and has a throughput of 160 Mbps. Since the onboard Ethernet only supports 10/100 Base-T, I'm con...
16 years ago --- Quote Start --- if you use malloc() calls to allocate a bloc of memory and use it to get the data from the DMA, you won't have any conflicts, even with other stuff put in sdram. --- Quote End --- Hi, I don't think malloc() function can allocate a block of memory in SDRAM. In my understanding, it will just allocate the memory of onchip-ram. Is that right?
