16 years agoethernet auto-negotiation blocked?
Hi, I'm building a data acquisition and transfer system using Ethernet. The data source is continuous and has a throughput of 160 Mbps. Since the onboard Ethernet only supports 10/100 Base-T, I'm con...
16 years agoif you use malloc() calls to allocate a bloc of memory and use it to get the data from the DMA, you won't have any conflicts, even with other stuff put in sdram.
