16 years agoethernet auto-negotiation blocked?
Hi, I'm building a data acquisition and transfer system using Ethernet. The data source is continuous and has a throughput of 160 Mbps. Since the onboard Ethernet only supports 10/100 Base-T, I'm con...
16 years agoThe Reset address should be pointed at some non-volatile location (onchip memory or flash). The Exception address should be pointed at RAM....in your case either onchip or SRAM, _not_ SDRAM :-)
Cheers, - slacker
