16 years agoethernet auto-negotiation blocked?
Hi, I'm building a data acquisition and transfer system using Ethernet. The data source is continuous and has a throughput of 160 Mbps. Since the onboard Ethernet only supports 10/100 Base-T, I'm con...
16 years agoYou have to look at your hardware configuration...specifically, the Nios II's settings...in SOPC Builder in order to find where your Reset/Exception addresses are located.
