16 years agoethernet auto-negotiation blocked?
Hi, I'm building a data acquisition and transfer system using Ethernet. The data source is continuous and has a throughput of 160 Mbps. Since the onboard Ethernet only supports 10/100 Base-T, I'm con...
16 years agoOk....where are your processor's Exception and Reset addresses? If either is pointed at the SDRAM, then that could be the source of the behavior you're seeing
