Amirb8
2 years agoEthernet Arch - Nios2, TSE and MSGDMA IP-Cores - REF Design
Hi, Is there a reference design that contains Nios2, TSE and MSGDMA (not SGDMA) IP cores? My goal is to verify if I successfully changed the old SGDMAs to the new MSGDMAs. In Eclipse I use the "S...
wwanalim_intel
Contributor
2 years agoHi Amir,
Are you using this template?
The closest reference design available I found for you based on your question above is this -
This reference design also come with tutorial.
Have a good day.
Fathulnaim
