21 years agoEthernet and DMA
Hi everyone, I'm working with a LwIP Stack (only using UDP) and make some timing measurements to find the nottlenecks of the stack. So I saw that the data transfer to the SMSC chip needs...
21 years ago@ tns1: I still use the 4.2 Version. I had no time to test the DMA controller with the SMSC chip but I'll test it next week. I read the errata for Quartus 5 and the SMSC.
For the 4.2 this problem is not mentioned. @amyler: I know the 0x0000 for UDP checksum is valid. But somehow I should check if the received data is okay. My HW checksum design works in the siumlation http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif . The real test will be next week.
