20 years agoeth0 not found
I am trying to bring up the Ethernet interface of my DE2 board, but it keeps me showing "SIOCSIFADDR: No such device" when I ifconfig it. I followed every step of the tutorial and I am using th...
20 years agoI have figured out what was wrong just after a good night of sleep. It's amazing how things get clear when you have a shower. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
I had forgotten to provide the proper clock to ENET_CLK signal! I knew I was missing something. Pehaps you are missing the same thing. Be careful of how you implement this clock. I did as follow and everything went ok:-- SOME CODE HERE
SIGNAL tmpClk : STD_LOGIC := '0';
BEGIN
-- ENET CLOCK (25MHz)
tmpClk <= NOT tmpClk WHEN CLOCK_50'EVENT AND CLOCK_50 = '1';
ENET_CLK <= tmpClk;
-- MORE CODE HERE
-- ... You can make this code without the tmpClk signal, I did it just for readability, but be sure of initialize the signal with "0" or '1' before applying the NOT operator. I also had a look at the uCLinux source and changed my IRQ to 3 as well. This is the default IRQ for DM9000 and I thought it would avoid later problems. Good luck!!
