20 years agoErrorwhile building Application Project
While Building Application Project I am using the hello.c file in /apps/samples/hello folder Makefile and the hello.c are added in the same project folder after Create Make Targret I am trying t...
20 years ago --- Quote Start --- originally posted by helmchen@Oct 26 2005, 02:12 PM change in your makefile topdir = .. into topdir = ./
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10588)
--- quote end ---
--- Quote End --- Hi, I'm experiencing a likely error when trying to build my µClinux application (although it build with no error as a C/C++ application) make: *** No rule to make target `display.c', needed by `display.o'. And so for each source file in the project directory. I'll be grateful if you can help me with that. Warm Regards
