15 years agoErrors during BSP generation -seeking help to solve
I'm new to using SOPC and NIOS. I'm using Quartus II 10.0. 1. I've instantiated NIOS II procesoor, onchip_memory, jtag_uart in my project. 2. Chosen all default options 3. Auto assigned base...
15 years agoLooks like your code footprint is larger than the memory you have allocated. I recommend looking at the Nios II software handbook and the various options you can use to reduce your memory footprint. Since you are working with the templates you can try the "hello world small" template to see the various setting changes in the BSP to reduce the footprint.
