13 years agoerror with NIOS2
Hello Friends , My design contains one .sof file and the board i'm using is TR4230 (Terasic) board. This people will give the gui kind of flash program. And by using this wind...
13 years ago --- Quote Start --- Try running this from the Nios II Command Shell: jtagconfig -n Take the output and post it here in the forum, that'll tell me what JTAG devices and IP are hanging off the programming cables. --- Quote End --- D:/a$ jtagconfig -n 1) USB-Blaster [USB-0] 024090DD EP4SGX230(.|ES) Node 0C006E00 JTAG UART# 0 Node 19104600 Nios II# 0 This lines appeared when i type that jtagconfig command
