13 years agoerror with NIOS2
Hello Friends , My design contains one .sof file and the board i'm using is TR4230 (Terasic) board. This people will give the gui kind of flash program. And by using this wind...
13 years agoIf you are using a Windows host make sure to open the "Nios II Command Shell". You can find it in the start menu under the Nios II EDS you installed. It uses Cygwin which allows Linux oriented tools to run in Windows.
