20 years agoerror with config the kernel
hi: today,I build tools, kernel on Linux according to the manual on http://hungryhippo.jot.com/wikihome,but (http://hungryhippo.jot.com/wikihome,but) with some problems,pl...
20 years agoI update the wiki about .bash_profile, http://nioswiki.jot.com/wikihome/operating...binarytoolchain (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/binarytoolchain)
About edit the build script, I mean you can comment out those had done successfully, just start from where it failed. But I don't use the build script approach now. If you are new to Nios2 uClinux, I would suggest you install the binary toolchain and follow the uClinux-dist approach. http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
