20 years agoerror with config the kernel
hi: today,I build tools, kernel on Linux according to the manual on http://hungryhippo.jot.com/wikihome,but (http://hungryhippo.jot.com/wikihome,but) with some problems,pl...
20 years ago --- Quote Start --- originally posted by hippo@May 28 2006, 09:05 AM the hungryhippo.jot.com is obsolete.
please use the new nios wiki, http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
please remove old uclinux-dist-test dir, then untar and patch again.
the dir name is uclinux-dist-test, but not uclinux-dist.
try "echo $path" and "nios2-linux-uclibc-gcc -v" again.
did you add the path into file ~/.bash_profile ? (if you use bash)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15626)
--- quote end ---
--- Quote End --- Sorry,I can't find the file ~/.bash_profile. I try out "nios2-linux-uclibc-gcc -v" after i did "PATH=$PATH:/opt/nios2/bin", it's ok. but restart the linux os, it's faild. Another question: what's mean "Then you can edit the build script, and restart from the middle"? Thank you !
