20 years agoerror with config the kernel
hi: today,I build tools, kernel on Linux according to the manual on http://hungryhippo.jot.com/wikihome,but (http://hungryhippo.jot.com/wikihome,but) with some problems,pl...
20 years agoThe hungryhippo.jot.com is obsolete.
Please use the new nios wiki, http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist) Please remove old uClinux-dist-test dir, then untar and patch again. The dir name is uClinux-dist-test, but not uClinux-dist. Try "echo $PATH" and "nios2-linux-uclibc-gcc -v" again. Did you add the PATH into file ~/.bash_profile ? (if you use bash)
