20 years agoerror with config the kernel
hi: today,I build tools, kernel on Linux according to the manual on http://hungryhippo.jot.com/wikihome,but (http://hungryhippo.jot.com/wikihome,but) with some problems,pl...
20 years agostep7 is wrong, don't cd ~/linux-2.6.x .
The uClinux-dist build procedure is a little different from the buildroot guide. cd ~/uClinux-dist-test make menuconfig Kernel/Library/Defaults Selection ---> (linux-2.6.x) Kernel Version (None) Libc Version [ ] Default all settings (lose changes) [*] Customize Kernel Settings [*] Customize Vendor/User Settings [ ] Update Default Vendor Settings Then <exit> <exit> <yes> . It will enter kernel config and apps config.
