11 years agoError while trying to program using HPS flash programmer
Hi, I am trying to program the binary file using HPS flash programmer for Altera Cyclone V. I had done a blank check operation using the command "quartus_hps -c 1 -ob". But an error i...
11 years agoYou need to set the BSEL (boot select) pins so that the board can be initialized. See the Altera programmer docs for details. If this is a dev board, the users manual should also have details on setting them.
