17 years agoerror while downloading Zimage
i followed all the steps in www.nioswiki.com/operatingsystems/installuclinux www.nioswiki.com/operatingsystems/uclinux/uclinuxdist and have a zimage which I am trying to download following ...
17 years agoWhich Dev board are you using?
make sure you follow http://www.nioswiki.com/operatingsystems/u...t/linuxhwselect (http://www.nioswiki.com/operatingsystems/uclinux/uclinuxdist/linuxhwselect) to select a device to execute kernel from From the www.nioswiki.com/operatingsystems/uclinux/uclinuxdist when you do the step # you must give the absolute path to ptf, no spaces allowed in the path.make vendor_hwselect sysptf=/path_to_your_hardware_project/your_system.ptf make sure you use your project ptf file then when you open a nios2 command shell 1) step 1. Configure the FPGA, nios2-configure-sof your_project.sof 2) nios2-download -g zImage 3) nios2-terminal
