21 years agoError while building the "Hello World" Project
Hy, I recently installed the Developement Kit for NIOSII (InternetEvalVersion) and tried to make the "hello world" tutorial with the std_1c20 core (also tutorial code). When I try to build i...
21 years ago --- Quote Start --- originally posted by rugbybloke@Oct 12 2004, 04:09 AM rleitner,
the ptf file is set in stage 4 of the tutorial after file->new->c/c++ application you come to a dialog box, one of the fields is the sopc builder system. you need to point this to a valid design as per the text
"browse to the location of the standard example hardware design that corresponds to your nios development board. for example, if you have the nios development board, cyclone edition, browse to:
<nios ii kit directory>\examples\verilog\niosii_cyclone_1c20\standard"
my guess is you're not doing this step --- Quote End --- I am sorry, you missunderstood me, I wasnot clear enough. I am already pointing on this folder ( I use std_s140). I am able generate the libary, and so on, write my own c code in the IDE, but when I try to build the project the error occured. Is there any additional Softwarepack needed ?(e.g. Java, ......)
