21 years agoError while building the "Hello World" Project
Hy, I recently installed the Developement Kit for NIOSII (InternetEvalVersion) and tried to make the "hello world" tutorial with the std_1c20 core (also tutorial code). When I try to build i...
21 years agoHy again,
after all the trouble, I installed my pc new. (except the" document and setting"- files. They are stored on a server). I also installed the latest java version from http://java.sun.com/j2se/1.5.0/download.jsp (http://java.sun.com/j2se/1.5.0/download.jsp) After my reinstallation of NIOS2IDE I got another error message. >make -s all >Creating generated_all.mk... >Oct 11, 2004 6:59:22 PM - (SEVERE) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: >java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.IllegalArgumentException: unexpected '(' in "ERROR in >function ptf_to_list: java.io.FileNotFoundException: \\ServerXXX.COM\Desktop_R\.sopc_builder\install.ptf (The system >cannot find the path specified)"f >make: *** [system_description/../obj/generated_all.mk-t] Error 1 >Build completed I know that the path "\xxxxxServerxxx.COM\Desktop_R\.sopc_builder\install.ptf" does not excist, so the error message makes sense. But how can I change this path? The correct path would be local on my pc \\c:\document and settings\rleitner\.sopc_builder\install.ptf So my question is: How can I change the path? Or what is the correct path of the install.ptf on a working machine? Thank you for your help!! Roman
