20 years agoerror when building tool chain
I am getting the following errors (lost of them) when I try to build the tool chain: toolchain_build_nios2/gcc-3.4.6-final/nios2-linux-uclibc/libstdc++-v3/include/ext/rope:2035:37: macro "index...
20 years ago --- Quote Start --- originally posted by hippo@Mar 29 2006, 10:28 PM what is the command you used to compile kernel?
do you have more message, 10 more liness?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13920)
--- quote end ---
--- Quote End --- Here it is: make ARCH=nios2nommu CHK include/linux/version.h CC arch/nios2nommu/kernel/asm-offsets.s GEN include/asm-nios2nommu/asm-offsets.h CC init/main.o CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o CC init/do_mounts.o LD init/mounts.o /opt/toolchain_nios2/bin/nios2-linux-ld: line 163: /opt/toolchain_nios2/bin/nios2-linux-ld.real: No such file or directory /opt/toolchain_nios2/bin/nios2-linux-ld: line 163: exec: /opt/toolchain_nios2/bin/nios2-linux-ld.real: cannot execute: No such file or directory make[1]: *** [init/mounts.o] Error 126 make: *** [init] Error 2
