Error: s0: Error during execution of "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.b
When you mention without update, did you work on the below?
sudo apt-get update
sudo apt install wsl
sudo apt install dos2unix
sudo apt install make
sudo apt-get upgrade
This is an important steps to follow.
I met the same problem,
uname -r return 4.4.0-19041-Microsoft.
I followed:
1) uninstall Ubuntu* 18.04 (if you have one)
2) uninstall wsl
3) re-install wsl
4) download latest Ubuntu 18.04 from Microsoft Shop & install it
5) execute following on Ubuntu shell :
sudo apt-get update
But not helpful.
The error still exist.
Error: s0: Error during execution of "{C:/intelfpga_lite/20.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: s0: Execution of command "{C:/intelfpga_lite/20.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: s0: /mnt/c/intelfpga_lite/20.1/quartus/bin64/uniphy_mcc.exe -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../q_sys_mem_if_ddr3_emif_0_s0_AC_ROM.hex -inst_rom ../q_sys_mem_if_ddr3_emif_0_s0_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_USER_ADD_0=0_0000_0000_0000 -DAC_ROM_USER_ADD_1=0_0000_0000_1000 -DAC_ROM_MR0=0001000010001 -DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0001100010000 -DAC_ROM_MR1=0000000000000 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0000000000000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0001000001001 -DAC_ROM_MR0_DLL_RESET_MIRR=0001010001000 -DAC_ROM_MR1_MIRR=0000000000000 -DAC_ROM_MR2_MIRR=0000000000000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=1 -DFULL_RATE=0 -DNON_DES_CAL=0 -DAP_MODE=0 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=0
Error: s0: UniPHY Sequencer Microcode Compiler
Error: s0: Copyright (C) 2020 Intel Corporation. All rights reserved.
Error: s0: Info: Reading sequencer_mc/ac_rom.s ...
Error: s0: Info: Reading sequencer_mc/inst_rom.s ...
Error: s0: Info: Writing ../q_sys_mem_if_ddr3_emif_0_s0_AC_ROM.hex ...
Error: s0: Info: Writing ../q_sys_mem_if_ddr3_emif_0_s0_inst_ROM.hex ...
Error: s0: Info: Writing sequencer/sequencer_auto_ac_init.c ...
Error: s0: Info: Writing sequencer/sequencer_auto_inst_init.c ...
Error: s0: Info: Writing sequencer/sequencer_auto.h ...
Error: s0: Info: Writing ../sequencer_auto_h.sv ...
Error: s0: Info: Microcode compilation successful
Error: s0: /mnt/c/intelfpga_lite/20.1/quartus/../nios2eds/sdk2/bin/nios2-bsp hal sequencer_bsp .. --default_sections_mapping sequencer_mem --use_bootloader DONT_CHANGE
Error: s0: nios2-bsp: Using /mnt/c/intelfpga_lite/20.1/nios2eds/sdk2/bin/bsp-set-defaults.tcl to set system-dependent settings.
Error: s0: nios2-bsp: Updating existing BSP because sequencer_bsp/settings.bsp exists.
Error: s0: Makefile:18: recipe for target 'setup' failed
Error: s0: child process exited abnormally
Error: s0: Cannot find sequencer/sequencer.elf
Error: s0: An error occurred
while executing
"error "An error occurred""
(procedure "_error" line
invoked from within
"_error "Cannot find $seq_file""
("if" then script line 2)
invoked from within
"if {[file exists $seq_file] == 0} {
(procedure "alt_mem_if::util::seq_mem_size::get_max_memory_usage" line 14)
invoked from within
"alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf""
invoked from within
"set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf"]]"
invoked from within
"if { !$do_only_rw_mgr_mc && !($bfm_mode || $hps_mode)} {
set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequenc..."
(procedure "generate_qsys_sequencer_sw" line 943)
invoked from within
"generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name $ac_rom_init_file_name ..."
invoked from within
"set seq_mem_size_list [generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name ..."
("if" else script line 2)
invoked from within
"if {[::alt_mem_if::util::qini::qini_value alt_mem_if_seq_size_request 0] > 0} {
set seq_mem_size [::alt_mem_if::util::qini::qini_value alt_mem_if_se..."
(procedure "alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer" line 238)
invoked from within
"alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}"
invoked from within
"set qsys_sequencer_files_list [alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}]"
(procedure "alt_mem_if::gen::uniphy_gen::generate_sequencer_files" line 3)
invoked from within
"alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR3" $tmpdir QUARTUS_SYNTH"
invoked from within
"foreach generated_file [alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR3" $tmpdir QUARTUS_SYNTH] {
set file_name [file tail $genera..."
(procedure "generate_synth" line
invoked from within
"generate_synth q_sys_mem_if_ddr3_emif_0_s0"
Info: s0: "mem_if_ddr3_emif_0" instantiated altera_mem_if_ddr3_qseq "s0"
Error: Generation stopped, 191 or more modules remaining
Info: q_sys: Done "q_sys" with 75 modules, 192 files
Error: qsys-generate failed with exit code 1: 23 Errors, 2 Warnings
Info: Finished: Create HDL design files for synthesis
