Error: s0: Error during execution of "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.b
Can you post the full error message? Looking into the short message, it does not seems to be relevant to this thread.
The generator unfortunately doesn't output the log into file and it can't be copied en-block from the message window.
But the list of error messages starts with
"Error: Error during execution of "{C:/intelfpga_lite/20.1/quartus//../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally"
and ends with
"<html>Error: An error occurred<br> while executing<br>"error "An error occurred""<br> (procedure "_error" line 8)<br> invoked from within<br>"_error "Cannot find $seq_file""<br> ("if" then script line 2)<br> invoked from within<br>"if {[file exists $seq_file] == 0} {<br> _error "Cannot find $seq_file"<br> }"<br> (procedure "alt_mem_if::util::seq_mem_size::get_max_memory_usage" line 14)<br> invoked from within<br>"alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf""<br> invoked from within<br>"set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf"]]"<br> ("if" then script line 2)<br> invoked from within<br>"if { !$do_only_rw_mgr_mc && !($bfm_mode || $hps_mode)} {<br> set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequenc..."<br> (procedure "generate_qsys_sequencer_sw" line 943)<br> invoked from within<br>"generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name $ac_rom_init_file_name ..."<br> invoked from within<br>"set seq_mem_size_list [generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name ..."<br> ("if" else script line 2)<br> invoked from within<br>"if {[::alt_mem_if::util::qini::qini_value alt_mem_if_seq_size_request 0] > 0} {<br> set seq_mem_size [::alt_mem_if::util::qini::qini_value alt_mem_if_se..."<br> (procedure "alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer" line 238)<br> invoked from within<br>"alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}"<br> invoked from within<br>"set qsys_sequencer_files_list [alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}]"<br> (procedure "alt_mem_if::gen::uniphy_gen::generate_sequencer_files" line 3)<br> invoked from within<br>"alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "LPDDR2" $tmpdir QUARTUS_SYNTH"<br> invoked from within<br>"foreach generated_file [alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "LPDDR2" $tmpdir QUARTUS_SYNTH] {<br> set file_name [file tail $gene..."<br> (procedure "generate_synth" line 8)<br> invoked from within<br>"generate_synth SDRAMController_s0""
The first apparently relevant message in the list is
"Error: Makefile:539: recipe for target 'obj/HAL/src/alt_dcache_flush_all.o' failed"
The "LPDDR2 Controller with UniPHY" uses Nios II for I/O calibration, so it's basicaly the same case as in the first post.
