Error: s0: Error during execution of "{C:/intelfpga/20.1/quartus/../nios2eds/Nios II Command Shell.b
Can you post the full error message? Looking into the short message, it does not seems to be relevant to this thread.
- FilipMiler6 years ago
The generator unfortunately doesn't output the log into file and it can't be copied en-block from the message window.
But the list of error messages starts with
"Error: Error during execution of "{C:/intelfpga_lite/20.1/quartus//../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally"
and ends with
"<html>Error: An error occurred<br> while executing<br>"error "An error occurred""<br> (procedure "_error" line 8)<br> invoked from within<br>"_error "Cannot find $seq_file""<br> ("if" then script line 2)<br> invoked from within<br>"if {[file exists $seq_file] == 0} {<br> _error "Cannot find $seq_file"<br> }"<br> (procedure "alt_mem_if::util::seq_mem_size::get_max_memory_usage" line 14)<br> invoked from within<br>"alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf""<br> invoked from within<br>"set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf"]]"<br> ("if" then script line 2)<br> invoked from within<br>"if { !$do_only_rw_mgr_mc && !($bfm_mode || $hps_mode)} {<br> set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequenc..."<br> (procedure "generate_qsys_sequencer_sw" line 943)<br> invoked from within<br>"generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name $ac_rom_init_file_name ..."<br> invoked from within<br>"set seq_mem_size_list [generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name ..."<br> ("if" else script line 2)<br> invoked from within<br>"if {[::alt_mem_if::util::qini::qini_value alt_mem_if_seq_size_request 0] > 0} {<br> set seq_mem_size [::alt_mem_if::util::qini::qini_value alt_mem_if_se..."<br> (procedure "alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer" line 238)<br> invoked from within<br>"alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}"<br> invoked from within<br>"set qsys_sequencer_files_list [alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}]"<br> (procedure "alt_mem_if::gen::uniphy_gen::generate_sequencer_files" line 3)<br> invoked from within<br>"alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "LPDDR2" $tmpdir QUARTUS_SYNTH"<br> invoked from within<br>"foreach generated_file [alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "LPDDR2" $tmpdir QUARTUS_SYNTH] {<br> set file_name [file tail $gene..."<br> (procedure "generate_synth" line 8)<br> invoked from within<br>"generate_synth SDRAMController_s0""
The first apparently relevant message in the list is
"Error: Makefile:539: recipe for target 'obj/HAL/src/alt_dcache_flush_all.o' failed"
The "LPDDR2 Controller with UniPHY" uses Nios II for I/O calibration, so it's basicaly the same case as in the first post.
