20 years agoerror message on eval board
Hi, Maybe someone her can help me because the Altera support stinks. If I had known they were going to take so long, I would have gone with Xlinix. Anyway, this is my problem: When I try to run ...
20 years agoYou could read the values of the sysid peripheral (using the IDE or your own C code) and compare them against what SOPC Builder generated. If they don't match, then you haven't downloaded the correct SOF.
This is, basically, what the default IDE Run/Debug launch configuration is doing. Best Regards, - slacker
