12 years agoError message in Nios II IDE
I don't understand this error message when I try to turn on optmization in Nios 2 IDE v10. https://www.alteraforum.com/forum/attachment.php?attachmentid=7837 Can you tell me why it happens a...
12 years agoYes, I use Windows 7. The stacktrace in the .log is
eclipse.buildId=M20060629-1905
java.version=1.6.0_14
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sv_SE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2013-10-09 08:52:25.758
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2013-10-09 08:52:25.758
!MESSAGE No more handles
!STACK 0
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:3400)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.SWT.error(SWT.java:3268)
at org.eclipse.swt.widgets.Widget.error(Widget.java:435)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:508)
at org.eclipse.swt.widgets.Sash.createHandle(Sash.java:114)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:523)
at org.eclipse.swt.widgets.Control.<init>(Control.java:98)
at org.eclipse.swt.widgets.Sash.<init>(Sash.java:72)
at org.eclipse.swt.custom.SashFormLayout.layout(SashFormLayout.java:115)
at org.eclipse.swt.widgets.Composite.updateLayout(Composite.java:989)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:1386)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3317)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1920)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:77)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3334)
at org.eclipse.swt.internal.win32.OS.EndDeferWindowPos(Native Method)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.java:703)
at org.eclipse.swt.widgets.Composite.resizeChildren(Composite.java:669)
at org.eclipse.swt.widgets.Composite.setResizeChildren(Composite.java:875)
at org.eclipse.swt.widgets.Composite.WM_SIZE(Composite.java:1390)
at org.eclipse.swt.widgets.TabFolder.WM_SIZE(TabFolder.java:836)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:1844)
at org.eclipse.swt.widgets.TabFolder.callWindowProc(TabFolder.java:158)
at org.eclipse.swt.internal.win32.OS.SetWindowPos(Native Method)
at org.eclipse.swt.widgets.Widget.SetWindowPos(Widget.java:1225)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:2133)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:2115)
at org.eclipse.swt.widgets.Control.setBounds(Control.java:2111)
at org.eclipse.swt.layout.GridLayout.layout(GridLayout.java:686)
at org.eclipse.swt.layout.GridLayout.layout(GridLayout.java:190)
at org.eclipse.swt.widgets.Group.WM_SIZE(Group.java:376)
at org.eclipse.swt.widgets.Group.callWindowProc(Group.java:128)
