20 years agoError ip header checksum
Hi all, I have a question about lwIP. I managed to set up a connection between PC and NIOS II. So far so good, when I send a message to pc it's ok. However when I send a message to NIOS and...
20 years ago --- Quote Start --- originally posted by dannyjacobs@Dec 16 2005, 02:08 AM hi slacker,
i disabled the udp checksum from nios ii to pc, but when i send a udp-message to nios ii from pc i alway get an incorrect checksum. it always says it is 0x0000 in stead of e.g. 0x4f7a. is this because lwip disables all ip-options!? and it works fine. everything works the way it should, but it is just something that bothers me...
cheers,
danny
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11606)
--- quote end ---
--- Quote End --- Danny, I suggest you either re-read Slacker's post or follow my advice on learning how to help yourself. A UDP checksum of 0 is not incorrect as Slacker said it means NO CHECKSUM. As UDP checksums are optional this is perfectly OK.
