20 years agoError ip header checksum
Hi all, I have a question about lwIP. I managed to set up a connection between PC and NIOS II. So far so good, when I send a message to pc it's ok. However when I send a message to NIOS and...
20 years ago --- Quote Start --- originally posted by dannyjacobs@Dec 15 2005, 02:29 AM hi all,
i have a question about lwip. i managed to set up a connection between pc and nios ii. so far so good, when i send a message to pc it's ok. however when i send a message to nios and look at it with ethereal i always get an incorrect checksum it's always 0x0000.
is this a known issue, because i can't seem to solve it. my data comes in correct, but it is just something that bothers me...
cheers,
danny
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11577)
--- quote end ---
--- Quote End --- I assume you mean the UDP checksum, if so I suggest you type "UDP checksum zero" into google or if you wish to understand TCP/IP buy Internetowrking with TCP/IP by Douglas Comer.
