16 years agoerror in niosII
hi I turn a code under niosII . I have this error I don't understant it Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused ...
16 years agoNiosII is not working.
Two possible causes: - timing problems in Quartus compilation In case, recompile the design after constraining clocks or reducing frequency - Nios is disabled because you are using an unlicensed core In this case you should not stop USB blaster connection after you have configured fpga
