21 years agoError in NIOS Dev Kit, Reference Manual ?
Hi I'm using Cyclone Development Board. I think that there is an errror in "Reference Manual" for that board. On figure 1-6 (page 1-13) pinout for connection betwen Cyclone and expansion co...
21 years agohttp://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif Yikes!
The last release of the Cyclone board manual somehow included incorrect pinout information for the PROTO1 header. We just identified the issue and will have a corrected version posted to the web ASAP. Note that this is not just an issue with J12. J11, J12, and J13 are all affected. I believe the PROTO2 header pinouts are unaffected, and the published pins are correct. You can use PROTO2 to get your work done. I will update this thread when the updated document hits the web. Thanks for pointing out this issue with Altera documentation. Matthew
