Paul83
2 years agoError in GDB server terminated with
Hello everyone, I'm currently working on a project using the Nios V processor on a Cyclone 10 GX. I've created the Nios V with the platform designer and generated the BSP. I'm using the Ashling Risc...
KianHinT_altera
2 years agoHi Paul,
I've checked our database, looks like it is a known issue
https://www.intel.com/content/www/us/en/support/programmable/articles/000092621.html
From engineering notes, the issue is still open.
I saw that you're already using RiscFree 23.4.1 ? Just to confirm as the issue was reported on 22.2 so that I could feedback to engineering.
Alternatively there is a workaround given by engineering team previously whereby you can try performing Debug with boot from serial flash by “uncheck” the Load image option.
The rest of the settings is still the same.
Kian
- Paul832 years ago
Hi Kian,
I try your advise and it seems it works. But even I checked the Load image box again, there is no problem
Thanks for your help.
Paul
