21 years agoError in compilation with cf component
I have made a system in SOPC with a compact flash component. When I try to compilate it I get this error: Error: Node instance "the_compact_flash" instantiates undefined entity "compact_flash". Does ...
21 years agoOk. Thank you. It worked when I manually added the Verilog files for the Compact Flash component and my own to the files tab under settings. I would have thought that this was automatic.
When will Altera release the next edition of Nios II? I suppose the Compact Flash interface will come with that. What kind of example code will you release? Ole Kristian
