21 years agoError in build
windows server 2003 enterprise edition, niosII 1.1 b137d, Quartus II 4.2 b157 when I create a new project in niosII IDE, such as "hello world", then Build All, the messenge appears: Error in ...
21 years ago --- Quote Start --- originally posted by tmiranda@Dec 13 2004, 01:47 PM you can explicitly set up the location where you'd like it to find your cygwin, and consequently make install. try the following:
- from window menu, select preferences
- in preferences select nios ii tool locations
- on that page, find the section labelled 'cygwin tools location (such as make, find, rm)
- even if it looks like it is pointing to the correct cygwin, select the radio option that says 'specify the cygwin tools directory'
- enter the valid path to the cygwin tools install e.g. d:\quartus\bin\cygwin\bin
- hit apply button
- hit ok
try to build again --- Quote End --- In niosII 1.1 b137d, altera removes the 'the Cygwin tools directory' option, there are only two options, niosII location and quartus location, i can not choice the cygwin location. In niosII 1.0, I can manully select the cygwin toolchains, and it seems that everything is ok.
