21 years agoError in build
windows server 2003 enterprise edition, niosII 1.1 b137d, Quartus II 4.2 b157 when I create a new project in niosII IDE, such as "hello world", then Build All, the messenge appears: Error in ...
21 years agoYou can explicitly set up the location where you'd like it to find your cygwin, and consequently make install. Try the following:
- From Window menu, select Preferences - In Preferences select Nios II Tool Locations - On that page, find the section labelled 'Cygwin Tools Location (such as make, find, rm) - Even if it looks like it is pointing to the correct cygwin, select the radio option that says 'Specify the Cygwin tools directory' - Enter the valid path to the cygwin tools install e.g. d:\quartus\bin\cygwin\bin - Hit Apply Button - Hit OK Try to build again
