Error generating SOPC Builder system after C2H acceleration
Hello all,
I have a problem using the NIOS II C2H Compiler. I tryed to accelerate a function by right-click its name and selecting "Accelerate ...." Then I selected the items "Build software, generate SOPC Builder system, and run Quartus II compilation" and "Use hardware accelerator in place of software implementation. Flush data cache before each call" However, when I click "Build project" I get the following error: --- Quote Start --- Error: Can't create file C:/Workspace/BB_DVBC/FEC_NIOS.ptf Error: System generation failed. --- Quote End --- If I click "Build project" again, I get the following message .... --- Quote Start --- **** Build of configuration Debug for project BB_DVBC_sw **** make -s all includes Creating generated_app.mk... 12.11.2009 12:46:22 - (SCHWERWIEGEND) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.io.FileNotFoundException: c:\Workspace\BB_DVBC\software\BB_DVBC_sw_syslib\..\..\FEC_NIOS.ptf (Zugriff verweigert) make: *** [/cygdrive/c/Workspace/BB_DVBC/software/BB_DVBC_sw_syslib/Debug/system_description/../obj/generated_app.mk-t] Error 1 Build completed in 2.75 seconds --- Quote End --- If I try to regenerate the SOPC Builder system using the SOPC Builder I get the same error as the first one ("Cant create file .... .ptf") and I have to use a backup to restore my files. so apparently the ptf file is corrupted after the generation in the NIOS IDE... does anyone have a solution or an idea what could be the problem ?? thanks in advance !13 Replies
You might be seeing the issue documented at the bottom of page 7 here: http://www.altera.com/literature/rn/rn_nios2eds.pdf
Sorry, I can't find a documentation on this issue ...
Neither in the document you provided (p.7 - 13) nor using google ... It seems that NIOS IDE (or SOPC Builder) sets the "write protection" attribute for the PTF file while generating the accelerator .. Even if I remove the attribute afterwards (the first error occurs in any case), I get the second error as well if I try it a second time ... - Altera_Forum
might it be a problem that I have a quartus II license, but no C2H compiler license ? So that quartus is set to generate non time-limited files, but c2h only can generate time-limited .. ?
BTW: I'm using Quartus II and NIOS IDE Version 9.0 SP2 - Altera_Forum
As soon as you use any IP in evaluation mode you will end up with a time limited sof file. So if you have a valid subscription to Quartus II but no C2H license you should be using the time limited sof file.
Also make sure that the SOPC Builder system has been generated at least once before attempting to use C2H on it. - Altera_Forum
Ok, my mistake ... the error occurs before the sof file would be generated ...
I have a valid project in quartus and the system has also been generated in SOPC Builder. Everything works fine if I dont use the C2H Compiler ... So I had my working project and clicked the function I wanted to accelerate, then I got the mentioned errors as described ... I really dont get it why it corrupts the ptf file .. - Altera_Forum
Hi, I have the same problem. can you please tell me that what you did to solve this problem?
Thanks in advance - Altera_Forum
Hello all,
I have a problem using the NIOS II C2H Compiler. I tryed to accelerate a function by right-click its name and selecting "Accelerate ...." Then I selected the items "Build software, generate SOPC Builder system, and run Quartus II compilation" and "Use hardware accelerator in place of software implementation. Flush data cache before each call" However, when I click "Build project" I get the following error: Quote: Error: Can't create file C:/Workspace/BB_DVBC/FEC_NIOS.ptf Error: System generation failed. If I click "Build project" again, I get the following message .... Quote: **** Build of configuration Debug for project BB_DVBC_sw **** make -s all includes Creating generated_app.mk... 12.11.2009 12:46:22 - (SCHWERWIEGEND) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.io.FileNotFoundException: c:\Workspace\BB_DVBC\software\BB_DVBC_sw_syslib\.. \..\FEC_NIOS.ptf (Zugriff verweigert) make: *** [/cygdrive/c/Workspace/BB_DVBC/software/BB_DVBC_sw_syslib/Debug/system_description/../obj/generated_app.mk-t] Error 1 Build completed in 2.75 seconds If I try to regenerate the SOPC Builder system using the SOPC Builder I get the same error as the first one ("Cant create file .... .ptf") and I have to use a backup to restore my files. so apparently the ptf file is corrupted after the generation in the NIOS IDE... does anyone have a solution or an idea what could be the problem ?? thanks in advance ! - Altera_Forum
I have this issue on Q9.1 on a Vista platform. If you look at your ptf after your first build, it is blank, that's why you can't build it the second time. => I just found out that for me it was Vista creating an issue. I just had to disable UAC and it worked. - Altera_Forum
I'm working on a XP system so in my case it wont be an issue created by vista. Currently I have a lot of other work to do but I still want to figure out what the actual problem is ..
Hi
I have the same problem too, using Win7 and Nios IDE 10.1 buid 153. Has anyone found a solution for this problem?
