16 years agoError generating SOPC Builder system after C2H acceleration
Hello all, I have a problem using the NIOS II C2H Compiler. I tryed to accelerate a function by right-click its name and selecting "Accelerate ...." Then I selected the items "Build soft...
16 years agoAs soon as you use any IP in evaluation mode you will end up with a time limited sof file. So if you have a valid subscription to Quartus II but no C2H license you should be using the time limited sof file.
Also make sure that the SOPC Builder system has been generated at least once before attempting to use C2H on it.
