13 years agoError: Eclipse (Code Stuck at printf function) Incompatible 2 value with TX_CMD_STAT
InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Your Ethernet MAC address is 00:07:ed:11:83:04 prepped 1 interface,...
13 years agohello There,
1. during porting the elf file to nios-ii eclipse generate a error saying "system console model is invalid", and then i run the run configuration and it port the elf file without any error 2. now with little modification in sopc like improving tse_mac receive buffer and on_chip memory...this code pass from stuck position (auto negotiations). and initilize tse_mac , butit won't respond to ping request it seems that tse_mac is not initialize. 3. after that i send data toward this system, it receive data, but at the same time the entire system re-initialize the interniche and every time i send data toward this system, it re-initilize and it keep reinitialize in loop mode. attached is print-screen of following events 1. As soon as i click on run to nios-ii hardware eclipse generate an error saying "system console model is invalid" 2. initilization and porting of elf file to nios and do not responding to ping request 3. As soon as it receive data, entire system is reinitiliza the InterNiche Regard kaushal
